Possible stupid question: will Porsche wheels fit the TT's pattern? >>
Specifically, will a set of 19" 997 Turbo wheels fit (obv with spacers, etc). The tires normally shod on them are Michelin PS2 235/35/19 front tires and 305/30/19 rear tires.
Thanks for putting up with this - I really don't know jack about wheels.
this of course will KW coilovers all the way at the last rear on rear with perches flipped.
I agree, that 305 is way to big but it would look so nice if it were possible to get it done on the TT.
You would have to run special adapters and spacers( GMP performance).You also cannot use the 65mm offset rear wheels, it's tough enough with the 45mm ones. Even then, forget lowering and you'll still probably need wider rear fenders. See my "new rims" post. I am fitting a set of hollow 996 rims, but I do have a fender kit.
<ul><li><a href="http://cgi.ebay.com/ebaymotors/Porsche-Carrera-997-Turbo-Wheel-and-Tire-Set-NR_W0QQcmdZViewItemQQcategoryZ66485QQihZ010QQitemZ 200099280541QQrdZ1">Turbo wheels on ebay</a></li></ul>
VenTTed
Wheels & Tires Discussion
05-04-2005 07:46 PM
dvsadversary
02-17-2003 06:46 PM
