Power Loss at 6500 RPMs??
I am experiencing a sharp drop in power at about 6500 to 7000 RPMs. I happens right around the red line on my TACH. Is this typical, should I not be revving into that area? Is it a DV??
Please provide any advice that you may have.
Thanks,
Jason
Thanks,
Jason
It's totally normal!
No car will have power within a few hundred rpm of redline! Shift to a higher gear and the turbo will kick in again and you will again pull strong to 5,000+ rpm.
Are you stock or chipped? If stock the redline is 6,800rpm, if you are chipped the redline will be 7,100rpm or higher.
Hope that helps.
Hope that helps.
captainbilly
01-27-2022 05:55 AM
PhoenixGTS
05-29-2002 10:04 PM
Kate
12-13-1999 05:54 PM
