power loss, need help >>
I've posted this issue before...
just want to try one last time.
I have a 2000 FWD. chipped, exhausted, CAI, etc...
starting a few months ago.. I started to expererience consistent power loss / drop off (very abrupt) around 4500 rpm under hard acceleration.
I have heard everything from "you need a new MAF" to "your little K03 can't put out much more" to "get a FMIC".
problem is... it didn't used to do this... even after all my mods.
is the turbo on it's last legs? what would cause such a harsh drop in power? no problems with the car other than this... (no smoke, no weird idle, sounds, smells, etc)
would a bad MAF not throw codes? is this tell tale signs of a bad MAF?
thanks guys!
andrew
thanks guys!
andrew
a bad MAF may not necessarily throw a code.
Can you get to a VAG tool to see if there are any codes?
Also, you could monitor certain functions to se what is happening.
I'd try this first.
I'd try this first.
Hibiscus Red S4
05-21-2005 06:42 AM
1.8tScreemer
08-03-2004 09:05 AM
74carrera
06-02-2003 09:13 AM
macrocosm
14
11-12-2002 04:58 PM
