Problem With overheat warning this morning>>>
About two miles from home this morning temp sensor maxed out and I got over heat warning. Having checked coolant level a couble of days ago I was sure level wasn't low, seeing no steam I continued driving with as few revs as posible. After two miles of driving temp gauge return to normal and warning stopped. Checked level when I got to wark and it was fine. Only thing I could think was thermostat was stuck.
I had the same thing just the other day although it didnt max out, but it was way higher than usual for a short period of time, interesting.
water pump impellers on cars with only 60k miles. I've got 53k on mine and it's scares the crap out of me. When I change all that stuff I'm going to use the ECS kit that comes with a metal impeller on the water pump, instead of the stock plastic piece of junk.
nvr_follow
11
02-10-2007 01:42 AM
jhoeppel
54
02-04-2007 08:44 PM
