Problem with strut bushing installation/removal of the 2nd 21mm nut
I was following MarTT's instructions on bearing/strut bushing removal procedures and was able to remove the old bushing and bearing. The problem I have now is trying to put everything back together.
The problem in particular is the "2nd" 21mm nut that holds the strut together. I do not have the right tool to really tighten it (though I was able to remove it). I have Koni struts and the top of the strut needs to be held down with an 11mm socket (not a 7mm allen as the normal strut has).
I am using a spark plug socket and an 11mm socket with a 6" extender that goes through the plug socket. This should enable me to hold down the top of the strut with the 11mm socket and turn the spark plug socket with a wrench.
The problem is the spark plug socket..It does not quite fit the 21mm nut perfectly and I am not able to get a good grip on it to tighten it properly. I also have an 02 sensor socket which fits a little better but the 11mm socket and extender doesnt quite fit inside of it.
I think my only choice now is to get a really deep offset wrench from Stahlwille (60 degree deep offset?). This would basically give me an open room to hold down the strut with the 11mm socket while I tighten it down. Problem is, I havent found a site where they sell just this one wrench and I dont want to spend $100+ for a whole set of Sthalwille wrenches that I wont need. I think this is the only choice I have for now, if anyone has any other ideas I would appreciate it.
I had the same issue...I filed down my 11 mm socket but still could not get proper torque...
Ended up doing the best I could and taking to my mechanic. He used an impact wrench to make sure everything was tight.
Naughtie
A4 allroad (B8 Platform) Discussion
02-03-2018 02:59 PM
mudd
42
03-24-2008 05:08 PM
Sully
10
02-08-2007 09:25 AM
Tom Faust
9
04-06-2005 03:06 AM
