Problems with window after replacing motor
The motor for the driverside window died, and I bought a new one and replaced it myself. Now it works but with a couple of minor faults. The window won't go all the way up/down if I'm not holding the switch all the time. And also when I open/close the door the window won't go down/up the half inch or so it did before. The latter don't bother me much but the first problem is a bit annoying.
Any idea how I can fix this?
You can try resetting the window. Might do the trick.
<ul><li><a href="http://search.audiworld.com/index.mhtml?q=window+reset&wf=022210&cat=0 10209&dt=range&db=01%2F01%2F1999&de=06 %2F21%2F2003">Window Reset</a></li></ul>
CheeseHead Cubs Fan
17
07-28-2005 01:18 PM
