Pulls to the right before Alignment pulls to the right after!!! Help. 180QC
1) you have low tire pressure in your right front tire, probably 36lbs versus 39 lbs or similar variance and
2) the person doing the alignment did not check tire pressures and, more importantly,
3) the person doing the alignment may have not checked abnormal camber against factory spec
Cameron
Cameron
it can generate a load in one direction.
Did it just happen, or has it been gradually getting worse? You might try this:
(I don't even know if car comes with full size spare..never looked. If it does, try spare on right front, then left front to see if tires change pull.)
Otherwise, interchange right front and right rear tires. If problem much less, probably the original front tire. Ask for adjustment from tire manufacturer.
If changing rights doesn't work, put tires back where they were and do lefts. It may not be right side tire.
Usually rears (even on Q) are less sensitive than fronts to tire imperfections.
It was a four wheel alignment, right?
Joe_M
10
09-06-2013 09:33 AM
prestonian
Audi Original "S" Cars
03-05-2008 04:51 PM
ski_steep
06-01-2005 04:11 AM
Zoomer
12-18-2002 12:58 PM
So i had some vibration at speeds 60 and above. I got balance and rotation vibration fixed. more....
Bill In SoCal
09-25-2001 01:18 PM
