question re DV
My TT comes in next month. I have been reading this forum and notice a lot posts regarding the OEM DV and how it has problems. What is A DV? And what are the problem is causes?
from its own pressure when the throttle is closed. When you shift between gears, the throttle is typically closed between shifts. Without the DV, the pressure produced by the turbo will feedback to the turbo potentially causing damage (stresses)to the turbo. The DV simply allows the air pressure to flow to the intake side of the turbo. A problem DV may allow feedback pressure to the turbo.
Hope this explains what the DV is and what it is used for.
high pressure air to the intake side of the turbo under closed throttle situations to keep the turbo spooled up to help alleviate turbo lag.
damaging it over time. So its primary purpose is protection with an added benefit of keeping the turbo spooled up between shifts.
EasTTcoasTT
12
11-14-2003 06:58 PM
Kriation
65
06-24-2003 02:24 PM
What RPM should the turbo kick in? It feels kinda jerky to me, but then I've never owned a turbo bef
Ms TT
11-05-2000 06:00 AM
DavidG
12-13-1999 06:54 PM
