Question for those with adjustable lower rear ties???
Can someone with adjustable lower ties please give me a total length measurement (from bolt hole to bolt hole) of one of the lower ties and tell me how much you have lowered your suspension. I only ask because I'm having a set of stock lower ties modified to be adjustable (tonight after work) and need to know roughly how much the stock length needs to be able to shrink. I know its kind of a big favor but I would really appreciate the help. Thanks guys! If no one has an acutal measurement does anyone have any idea..1 inch..2 inches?
i actuly bought a camber gauge and play around with them a lot at the track....
that I would be able to get within speck with 2" or adjustment on just my lowers for a 1.25 drop? Thanks again!
My Quattro is down 1.5" (Neuspeed sport springs)and I opted for the lowers available from Forge. At a 1.5" drop, we had plenty of adjustment room and they are very nicely made.
well it depends on how they mod your arms to make them adjust, mine have a joint at each end that threads in to the center, and i used extra long shanks on the joints so that i can have so much adjustment and be safe
I was able to restore camber to -1.2 degress with a 1.25in drop with "Strat" bars, and had lots of adjustment left. I doubt if they provide more than an inch of "shortening" ability. The ability to get shorter is the only thing that counts (in the lower arm) to correct excessive negative camber. Lengthening will only be needed if you raise the car.
zszabo
03-15-2004 05:34 PM
odelay12v
10-21-2003 11:12 AM
pyite20v
07-10-2002 08:17 AM
