Question for you 8.5" F & 10" R wheel fitment folks.
Old 09-26-2002, 12:11 PM
  #11
Senior Member
Alf Garnett's Avatar
Gimmie an hour and I'll email ya...
Old 09-26-2002, 12:12 PM
  #12
Senior Member
TTigg's Avatar
35 front is OEM offset (I think) so might need spacers to clear your up and coming brakes
Old 09-26-2002, 12:26 PM
  #13
JazziTT's Avatar
Default Please e-mail to.... TIA
hugh199@attglobal.net
Old 09-26-2002, 12:29 PM
  #14
JazziTT's Avatar
Default They're recommending a 5mm spacer
Then I'd be at 30/30
So, all this means is I'll be pushed out towards the fender edge 5mm more than stock (plus the added width of the wheels?).
Old 09-26-2002, 12:41 PM
  #15
Member
MAX@edgeracing.com's Avatar
18x8.5 ET30, 18x10 ET20... hope this helps
Old 09-26-2002, 12:43 PM
  #16
JazziTT's Avatar
Is ET30 with an 18X10 going to be a problem?
Old 09-26-2002, 12:49 PM
  #17
JazziTT's Avatar
Sounds like adding a 10mm spacer to the rear would be the answer..Yes?
Old 09-26-2002, 01:00 PM
  #18
Member
Default That would be a solution if the wheel doesnt bolt right-on
Usually 18x10 5x100 wheels are made for the TT as a main market so I would guess those should fit fine...
Who makes this wheel? Knowing who the manufacturer is should help
Old 09-26-2002, 01:03 PM
  #19
JazziTT's Avatar
Brock.... B2's
Old 09-26-2002, 01:10 PM
  #20
Member
Default hmmmm... those are probably intended for MKIV VWs but they might work...
You do have the spacer option if they don't.
Ask whoever is selling you the wheels... they should know what they're doing regarding offset, center bore and hardware issues.
Hope this helps
MAX
Quick Reply: Question for you 8.5" F & 10" R wheel fitment folks.
