Questions..... Fluid in the rear diff is supposed to be a "lifetime fluid" according to>
<center><img src="http://buy.snapon.com/catalog/OBJECTS/20700/20688.JPG"></center><p>Audi. Before I change it, I thought I'd get the forums take on it.
I decided to change my transaxle fluid to Redline 75w90 synthetic after an extensive search of the forum. Redline recommends MT90, but evidently some have had difficulty in the TT 6-spd with it being a bit too heavy. Believe this was mostly in colder climates. It also appeared that the MTL might be a bit "light" for street use. After reading JimTT's take on it, I decided on the 75W90 in the transaxle. This is what is recommended in the rear diff as well.
BTW.... the transaxle takes a 14mm hex key. I used a 14mm hex socket driver like the one pictured. The rear diff takes a 17mm hex. However, there isn't enough room for a 17mm socket driver. May have to shorten the shank, or buy a specialty tool.... Has anyone else changed the rear diff fluid? If so, what fluid did you use, and did you modify a hex wrench/socket, or buy a specialty tool?
Thanks.
Thanks.
He installed I believe the same fluid into the diff as the tranny, all according to what RedLine recommended. Not certain if it was 75w90 or MT90 though.
it is about 1" in total length and can't come apart. I got it for my truck to change the engine and tranny and diff oils. Have had this for about 12 years.
which is the only thing that would work for me.
If you live any where near "real" stores (the Checker conglomerate, I hear . . . ) you might find a real answer.
What I did: buy a 1" 10 mm bolt (these take a 17mm wrench, remember) and 2 nuts to fit - double nut on the end of the bolt.
Yes, it becomes tiresome. But less so than a $10K rebuild on the old transaxle.
ttfn
ttfn
I bet you could cut a hex tool (L shaped looking tool) down and use a 17mm wrench to turn it. Follow me?
Shoot me your address and I'll mail it out to you.. I have 2 (of these) so you can have one.
make my own wrench. However, fortunately for the neighbors, I don't own any welding schtuff.
