Quick! Help Needed! My drivers side window will not roll up.
Which fuse should I pull and reinsert? The diagram doesn't list the windows. It's 30 degrees here and I rather not drive on the expressway with my window down.
Thanks
Thanks
If both windows arent doing it I dont think it could be a fuse infact I dont think they have fuses as they are automatically resetting breakers. Sounds like the motor has gone. Was it playing any tricks before this happened - if so the motor was showing signs of it. If it just happened it must be a wire around the motor....NOT the switch inside as the key codes would work and the key in the door would also work. Try giving the door a thump around the cargo/holder net thingy to see if something startles it. Does it click when you try to use the switch - Like its trying to work. If so --- keep trying it.
Are you under warranty.
and since it also doesn't work from the inside switch, it appears likely to be a problem with the window motor/controller. Unless it's something like water freezing the window in place.
RipGroove
TT (Mk2) Discussion
9
12-19-2017 08:42 AM
Tink
04-05-2012 11:55 PM
heinzboy57
11-29-2008 12:19 PM
