rattles & electricals
Guest
Posts: n/a
anybody having problems with rear seatbacks rattling and weird interior light/electric door lock behavior on a ttq? the electrical problem seems to be tied to the door lock, since if the door is opened (or if the handle is pulled in the locked condition) all of the problems go away.
thnx 4 any ideas!
thnx 4 any ideas!
Guest
Posts: n/a
If you lock your doors using the button on the center console BEFORE starting your car, the interior light WILL NOT work! You also will not be able to use the same button to unlock your doors. Just start your car before you lock your doors and the problems will not appear. There is supposedly a fix for this (grounding pin 2, pin 2 of what, I don't know) but for the time being this is how to avoid these problems.
Guest
Posts: n/a
Have been having seat back squeeking when car is cold. Dealer unable at this point to resolve.
Dealer recently corrected the door locks/lights problem with the grounding wire patch. They reported that Audi is working on a software fix (that would not require the physical modification) for this problem but is isn't available yet.
rogeryang56
03-09-2015 04:34 AM
ToplessQuattro
10-16-2005 09:29 AM
PatenTT
05-27-2001 10:39 AM
evan
02-02-2001 07:23 PM
