Re: water gauges and AC ECT temp readings: data and Questions.
AudiWorld Awesome User
For my 2000 TTQC, I did the following
- AC or Economy, doesn't matter
- depress/hold Recirc button
- depress Up button and release both
- LED display goes bright and flashes one of the C-codes (they go 1C to 79C)
- rotate (turn-and- hold works) fan speed selector (LH **** in US) CW or CCW until you get the 49C code
- depress and release recirc button, display shows C* temperature.
My TTQC runs about 83*C here in SE GA right now. Hard acceleration up to 160k/96m makes about 85*C.
OK, here's my question:
- who has the breakout of all the C-codes?
- If no universal ist, which one is oil temp, boost, a couple of others?
TIA!<ul><li><a href="https://forums.audiworld.com/tt/msgs/447835.phtml">One of the original threads</a></li></ul>
Someone did this code list, I cannot remember who but I'm not going to take any credit. Hope it helps.
https://www.audiworld.com/tech/int6.shtml<ul><li><a href="https://www.audiworld.com/tech/int6.shtml">https://www.audiworld.com/tech/int6.shtml</a</li></ul>
ROMTT
10
06-10-2006 06:29 AM
