Rear brake pad tool - really necessary??
I'm expecting my new pads and rotors to show up today. Do I really need the special tool to install pads in the rear? Any tips? Thanks!<ul><li><a href="http://www.dieselgeek.com/Detail.bok?no=313">Metalnerd / Dieselgeek tool</a></li></ul>
You have to both turn and compress the caliper piston to get it to retract. I've used the ghetto method of a C-clamp and channel locks but would never do it again without the tool.
I think you can rent one from Autozone.
Went to Advance Auto and they "lent" me the caliper set (had to leave a deposit). Also picked up the cheap version just in case.<ul><li><a href="http://www.partsamerica.com/ProductDetail.aspx?MfrCode=APO&MfrPartNumber=T 71921&CategoryCode=3479">http://www.partsamerica.com/ProductDetail.aspx?MfrCode=APO&MfrPartNumber=T 71921&CategoryCode=3479</a</li></ul>
I used a pair of needle nose pliers that have a wide end - mine fit perfectly in the caliper piston. I had a friend hold the caliper while I turned it. You have to push the piston in while you turn it ... and be careful not to slip and stab your friend.
