Removing struts what tools do I need.
#13
...also some bolts that are not as critical as others when tightening. Rod bolts have to be spot on but a 10mm bolt that holds your horn on does not. I have developed a good feel for bolt torque; you can practice with a torque wrench and a lever arm of the same length. BTW many shops do not use torque wrenches in many situations, I know because I was a Honda Mechanic many years ago. There also is some common sense here, the smaller the bolt the less you tighten it, I would say many guys over torque on the theory that if a little is good more is better. It is maddening to work on a vehicle that has a bunch of over tightened bolts!!! If you can get a torque wrench on a bolt do it if not you must get close by feel. JIM
Jon-1.8t
Florida Discussion
08-26-2005 05:58 PM
TurboEnvy52
10-08-2004 11:45 AM
coasTTal
06-20-2004 03:09 AM
grishfish
06-21-2001 09:59 AM
