Replacing DV to Recirc. valve (N249) hose
Hi all,
I need to replace the small diameter hose that goes between the DV and N249. The diameter on the DV side appears to be different than that at the N249 so I could't just replace it with a straight hose, plus there needs to be two right angle bends which complicates matters. Audi is asking for over $160 CAD for this (ouch). I would like to replace it with silicon hose.
Should I use two right angled adaptors and pieces of straight silicon hose for this. What are the actual diameters I need at the DV side and at the N249 side? Which is the best place to source these supplies (preferrably in Canada)?
Thanks,
Henry
Thanks,
Henry
No 90 degree fittings necessary. Silicone os pretty flexible. $5 oughta do it..
<img src="http://images2.fotki.com/v19/photos/7/7305/201596/DSCF0054-vi.jpg">
<img src="http://images7.fotki.com/v125/photos/7/7305/201596/DSC02940-vi.jpg">
A4TURBO2 // TMK
10-16-2001 06:57 PM
2001, a4, a6, anderson, audi, hose, n249, pam, recirculating, recirculation, removing, replace, replacement, tt, valve
