replacing the front blinkers in the headlight...
Hello Peoples,
I just bought some piaa replacement bulbs for the front blinkers inside the headlight, but i don't know how to take apart the headlight so that i can replace them. do i even need to take apart the headlight? if anyone can help it would be appreciated. Thanks.
GO DEVILS & NETS, ONE DOWN, ONE TO GO!!!
I do not have the diagram, but if you look to the bottom and away from the grille behind the headlight assembly in the hood you will see 2 twist style caps. Twist and remove bulb. Real easy, once someone posts the diagram.
SCarGo02
12-29-2006 07:31 PM
