Replacing synchros- only replace for my 2-3 grind, or replace more?
I think they run ~$150/pc. I'm replacing 2nd and 3rd, any others? I hate to throw away $$ when there are other things I need to repair/replace.
All the synchros have been redesigned I hear.
only the car does it for you. I used to get a grind when I shifted from 2nd to 3rd gear above 4,000 rpm before I switched to redline MT90. If I doubled clutched it wouldn't grind. Which means it is most likely a synchro problem.
