Report on trans fluid change FWD
This is a straight forward job. The same engine cover that is removed for an oil change must be removed to change transmission fluid. A 17mm hex key is all you need to remove the drain and fill plugs (Sears $9.00). Two quarts of gear lubricant are needed (measured drained fluid) I used Valvoline GT-5 75w-90 synthetic gear lubricant. The fill plug is located on the front vertical part of the transmission housing. Thus you cannot poor the new fluid in but rather must pump it in somehow. I used a hand held metal oil can pump you can pick up at any auto parts store. Mine only holds about a pint and a half so it takes 15 minutes to get it all in. I want to say this is a two thumbs up as to the results because it seems the car shifts so much better (I never had any gear grind). However I only going to give it one thumb up because of the possible placebo effect; I'll drive the car for another month then report back.<p><img SRC="http://pictureposter.audiworld.com/AudiWorldPics/2000/JIMTSIGTTFORUM.JPG"BORDER=0></A>
audi_marv
06-26-2013 10:43 AM
Shep 1.8T
03-30-2003 07:30 PM
Black Sunshine
12v V6 Discussion
23
03-18-2003 12:40 PM
nklemens
Audi 100 / A6 (C4 Platform)
03-25-2002 12:53 PM
