Reprogramming key fob after battery replacement
#41
1# you take one key put into ignition turn on.
2# close door, lock it with the key hole on driver side,with the key you want to program.
3#once it's lock take the key of the door out press the open button once or 2 or 3 or 4 times depending on which key is being reprogrammed(for the seats memory)you will see your side blink every time you press ,wait 6 secs press again once.take the other key in ignition out.
close the door and try locking with the reprogrammed key.
if you lost the program on other key it's just you didn't select the right memory,so set the right number for the right key
Ex:my wife is 1# in memory seat,mine is 2#.
so i had to press twice in 3# step.
what if your ignition is not the same lock as the ones on your doors cause you had to replace your ignition?
Yogee
04-06-2006 06:01 PM
