Scangauge HP numbers. WHAT THE !@#$?!
Uhhh, I am pretty consistently getting 277.
And then I'll get 254...
Seems like 254 happens in 4th and 277 happens in 3rd.
This cannot be right... how is horsepower calculated with this gadget?!
I just have a pretty much stock 225 with GIAC and exhaust. (No DP) Oh and the 4bar and ****/BoostMachine.
I mean, I'll take it... but sheesh. Doesn't sound right....
If not then you haven't reached the peak yet and you're reading a HP value on the still ascending part of the curve.
This is why it's better to get a good reading in 3rd where you only have to hit 82 mph to get to the peak HP.
BC
BC
you are getting some spikes maybe by letting off the throttle too fast. If so, try a 3rd gear run but once you hit the RPM's which will yield the highest MAF readings (like 7000), try slowly backing off the throttle from there as opposed to lifting your foot off the gas pedal. I take it that it only records peak readings.
the amount that the MAF is low due to the ****. The MAF air flow rate is down by 11% since the **** adds an 11% area increase which makes the MAF reading low by the same amount which makes the HP reading low by the same amount.
BC
BC
now you state that that number was confirmed by the 215 HP dyno run. If that is the case then you're getting a 32% loss in the drivetrain. I was under the impression that the drivetrain loss for a TT was more like 20%. I sure don't see any confirmation here.
BC<ul><li><a href="https://forums.audiworld.com/tt/msgs/1743639.phtml">https://forums.audiworld.com/tt/msgs/1743639.phtml</a</li></ul>
