Scangauge HP numbers. WHAT THE !@#$?!
#21
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1745723.phtml">https://forums.audiworld.com/tt/msgs/1745723.phtml</a</li></ul>
#22
calculated based on the measured MAF air flow rate and the stoichiometry. I'll have to search to find it. When I do I'll post it.
But if this is the case, then the MAF does directly control the calculation and the 1.11 factor applies. IF not then it is more muddled.
BC
BC
#23
with a 4 bar and the computer knows nothing about this little juggling act...
The fuel is definitely measured by the injector rate Using the known 386cc delivery rate (at 3 bar). The 4 bar alters this by +25% though..
Only the down stream readings by the 02 catch it.
So...Less air being recorded by the MAF, but more fuel actually being delivered by the 4 bar....With the 02 balancing it all out, the net effect is probably marginal (since the STF's and LTF's come in within a few %) I think the .11 you're assuming is not realistic in the overall calculation..
rktskicar
30
10-03-2005 10:18 AM
MachtigAvant (v3.0)
05-23-2003 06:35 PM
