search sucks and links to how to romve the ctr console??
Remove both triangles (four hex screws)
Remove plastic tunnel trim on both passenger and drivers side foot wells (behind the triangles towards the engine)
Remove shift **** (threads off)
Remove trim ring and shift boot
Remove small plastic piece below e-brake
Pop out gas tank, truck switch panel, remove plugs
Pop out lock/unlock, nav switch cluster, remove plugs
Grab the front of the center console where the triangles were a spread it open.
Pull up, center console should come right out.
Then unplug the air bag light.
Hope this helps....
Hope this helps....
then, you need to take the cup holder off (2 screws) then under that, you will notice a few more screws to take off. that will pretty much get you close to where you want to be.
you just passing wires through? or taking them off completely?
audithepeanut
12-28-2008 12:27 AM
Jason in Vancouver
07-17-2002 06:39 PM
addifan
05-04-2002 03:23 PM
