Secondary Valve question: After speakin to two audi tech guys they told
me that the 225 has two?? diverter style valves...? with the primary being the usual one under the engine cover and the other one being in back outta of view near the motor? is this true? they said theres two valves due to their being two intercoolers? but only one turbo? they said they changed a couple of valves on a few TTs...I also spoke to someone at dealership who said he has had secondary DV changed.,,is their another DV or is it somekind of shunt or check valve...if so does anybody have any part #s or spec sheet....would like to check my other valve out to see if its leaking to...thanks
the TT has one DV. It may have some other valve someplace, but its not a second DV. It has nothing to do with the IC's.
all AFAIK, YMMV. :-)
I thought the dealer guys were wrong to.....but the one tech guy is really good....he routinely gets invites to work on the factory LeMans cars....but I do agree that two dvs on a car with one turbo sounds wrong....
some sort of solenoid or actuator that makes it work. Seems reasonable that is what they might mean. Now that I think about it, I did hear about a guy who had that part fail, and is was sending exhaust out the back via the wastegate instead of spooling the turbo. Car had very little boost at all = not much power. Its not a DV, but I suppose it could be the culprit in your case.
<img src="http://albums.photopoint.com/j/View?u=1524173&a=13620968&p=53501859">
Vacuum System
1 - From fuel tank
2 - EVAP canister
EVAP canister is located at rear, below at vehicle floor, below a cover
3 - Check - valve for EVAP canister
Between EVAP canister and intake manifold before turbocharger
Installed position (light/dark half): arrow points in direction of flow, as shown
4 - Turbocharger
5 - Pressure unit for boost pressure regulation
6 - Mechanical recirculation valve
7 - Brake booster
8 - Check - valve
Between brake booster and intake manifold
9 - Wastegate Bypass Regulator Valve - N75 -
10 - Mass Air Flow (MAF) sensor - G70 - 11 - Air filter
12 - Pressure regulation valve for crankcase ventilation
13 - Vacuum reservoir
Bolted on at cylinder head
14 - Fuel pressure regulator
15 - Intake manifold
With Intake Air Temperature (IAT) sensor - G42 -
16 - Check - valve
17 - Turbocharger boost pressure recirculation valve - N249 -
18 - Secondary Air Injection (AIR) solenoid valve - N112 -
19 - Crankcase ventilation
20 - Secondary Air Injection (AIR) pump motor - V101 -
21 - Throttle valve control module - J338 -
22 - Charge Air Cooler
With charge air pressure sensor - G31 -
23 - Check - valve
Vacuum System
1 - From fuel tank
2 - EVAP canister
4 - Turbocharger
7 - Brake booster
8 - Check - valve
16 - Check - valve
23 - Check - valve
