Seconday Air Injection Someone??
Whats up everyone. I kept getting this secondary air inj. code incorrect flow and the dealer has replaced the combination value twice. Is there anyway to check this with a vag-com and what is the purpose of a combination value? Two part question. Thanx
TT225,GIAC,Bailey....
Is the air pump definitely functioning during cold engine starts? Usually you can hear the pump during the first minute of a cold engine start. If it's not running, then it's either siezed, not getting a signal from the ECU, or there's a shorted wire to the pump. Anyway, if it does seem to be working, then there is probably a leak somewhere in the secondary air system. I've had luck in the past using a soapy water mixture in a spray bottle to find the leak. Sort of like a bicycle tube leak check.
In the dealership's defense, secondary air injection codes are a real pain in the *** to diagnose. Good luck.
<ul><li><a href="http://www.springbreakdaytonabeach.com/vwtech/www.vwwebsource.com/vwtechcontent/audipdf/a010006.pdf">link</a></li></ul>
Nichole77
12
04-04-2016 01:16 AM
A6AvantErik: MCS
Audi 100 / A6 (C4 Platform)
05-27-2008 07:30 AM
audifirst
04-16-2008 02:59 AM
