Servicing Forge DV? Is this true?
Just had to re-lube mine this weekend because it was sticking.... got a CEL warning too...
Even with the aluminum piston and the improved orings with the Forge upgrade, the unit did stick/slow to react. After I took it apart, I found that the lubricant had dried out and was very "tacky". I used some high temp synthetic grease (used for brake calipers), we'll see how long it lasts this time... The lubricant is a major achilies heel for the Forge unit - this is the third time I have had to service mine.
T
T
duffman1101
10-15-2003 12:25 PM
