Sirius satellite radio and antenna install -- complete and unabridged
#15
I hardwired it using the Soundgate adapter. The reason I opted for this rather than Jeff Bipe's auto sensing switch, is that I have two external sources, the roady2 and an ipod. Jeff's works with only one external source. The soundgate has a 3-way toggle switch that toggles between ipod, roady2 xm and OEM CD magazine.
I used a 6 to 12 VDC transformer to hardwire the power to the ignition key switch.<ul><li><a href="http://www.logjamelectronics.com/soundsds1.html">soundgate adapter</a></li></ul>
#16
for $70 I might try it...but I got this for now...at least the inline antenna link up should make for better sound...<ul><li><a href="http://www.xmradio.com/catalog/product_detail.jsp?id=28448&type=Accessory">xm kit supposedly works on sirius units...</a></li></ul>
#19
just to make sure it's not leaking. Still a little worried about that.
As far as the magnet not holding, I don't think that will be a problem. That sucker is strong. I can barely lift it off... it was to the point that it got annoying when I was installing and kept "accidentally" setting it down. I'd say it's not going anywhere, but thanks for the caution... will still keep an eye on it.
#20
Plus, the plastic edging around the actual screen flares out, so it doesn't block any part of the screen when viewing from that angle.
