small coolant leak on start up. Then it goes away when warm.
So last week my wife wants to take the TT out. As she backs up i see a small pool of coolant under the car. I get the car up on ramps and can see from the right side of the motor when looking up there is some coolant spalshed about but now none is leaking?
It seems that only when the car is cold, like it has stood for several hours or overnight, when started it looses about an 1/4 of a cup of coolent.. then stops..
If i leave the car running it just clears up and stop leaking..
I assume this is a water pump or water pump seal but i'm totally guessing.. Anyone got any ideas?
Thanks
Dave
Thanks
Dave
Re: The turbo after-run coolant pump is a common source of leaks.
i dont think its that. only because i know where that is and its not leaking or wet there. it seems to be lower. could it be a return hose from that pump perhaps?
That said could it also be as suspected a water pump or is that out of the question?
Thanks
Dave
Thanks
Dave
Could be anywhere I suppose. Leaky waterpump is not out of the question, but unless you've had that
recently changed, I've not heard of a water pump that started leaking. Has the water pump been recently changed? If so, maybe it wasn't tightened down enough...
Re: Could be anywhere I suppose. Leaky waterpump is not out of the question, but unless you've had
Nope its been the same pump for at least the 10k i have owned the car. It seems odd that when i looked again tonight there is no leak when the car is warm. But i know when i start it up in the morning it will leak, I think i may have to put it up on ramps overnight and start it when i am under it cold in the monrning to see where it is coming from.
BHase
09-27-2004 04:02 AM
SteveJ_in_TX
02-25-2003 12:38 PM
