So I have my KW 8012 springs in the rear, and I STILL have one perch all
the way down (the other about 1/4" up)... I wouldn't mind going little lower, but I need adjustment to keep it corner balanced. Guess my only option is to cut the springs, or find some that are lower from another manufacturer? Certainly lower than the original springs, but not as low as I was hoping they would be...
cut springs rarely work well. Tried it... it seems to increase the spring rate disproportionately. You get "bounce".
<center><img src="http://pictureposter.audiworld.com/107981/dropped7_500.jpg"></center><p>I dont have height adjustment in the rear anymore and only have height adjustment up front but I am as low as I can go in the rear with the 8012 springs with 18" wheels. If I ever run 19's, then I may end up putting the rear height adjusters back on.
piece under the rubber as well. most likely...like with mine, it has rusted into place.
what i did was to use a small crowbar and gently lift up all the edges upward until it gave way. it was rusted on the center bump stop with the inner ring...if that helps. it was hard to understand how it was placed in until i removed one of them (the easier of the two)...once i saw how it was put in, the other was easy to get out.
so the rubber pin goes through the bottom spring platform...so it won't rotate...which is why you won't be able to rotate it free until you get the rubber pin out of the slot.
islingtonaudi
Audi 100 / A6 (C4 Platform)
12-31-2008 01:17 PM
MSP_S4
01-19-2006 04:49 PM
cabriolet rear springs (8G0 511 115a) are cabriolet specific springs fronts are same as B4 except 93
wisconsin_quat
15
09-05-2003 05:31 AM
