So what's invovled in a T-Carbon FMIC for a 180 FWD?...>>>
#15
much easier to just purchase a new manifold for them and pass the cost on to you. You guys forget that there are TONS of FMIC's available for the 1.8T for VW's which will most likely simply bolt on to the TT with a minimum of modifications to simply locate correct mounting points.
#16
but you's right - there's a huge amount of development out there on the 180/1.8T; my bias was what worked here & given my level of knowlege at the time - but I *had* found a lot of options, just no install history. Lately I'm looking at them again though - mostly to educate myself on turbo and programming options.
#17
I'll be in the market come April/May.
Although Forge is literally right down the street from me (so support would be easy) I never liked the idea of having the extra expense & hassle of the 225 manifold.
I'll most likely go with the APR setup if nothing else is available by then ;-)
#18
I've been told the black pipe there is OEM. I never knew that, need to check. I'm considering this way because:
A) I could use the same core.
B) I could use the same mounting brackets.
C) It visually looks better from the outside.
D) Since that's a hard pipe, there shouldn't be a pressure drop issue.
