some one please explain this to me...
all four new coils and regap plugs at .32 (all 4 plugs are about 10-15k miles) and yet still have misfire logged in VAgcom under 1k rpm and some rand 2-2.5k rpm. what the hell???? what am i missing?
as far as i can tell, the car feels great and running strong. holding 21psi without any problem.
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1566241.phtml">https://forums.audiworld.com/tt/msgs/1566241.phtml</a</li></ul>
contact info. i must consult with him before i do any of the replacement... is there any other theory?
Take a good look at your harness..The insulation breaks will be noticeable if this is the problem...
You didn't use cheap copper plugs did you?
while idling... no code, no weird hesistation, no boost cut off, nothing... car pulls... and i've read the tsb from andrew.tt so i guess i'll check the wiring harness for cracks. doubt it. watever if the car runs and pulls strong, i wont let this stupid ordeal bothers me.
