Some Pics from the barrett-jackson auction in LA...
My ddad's '59 caddy sold for $50,000... I was expecting more, but it was a good auction.<ul><li><a href="http://share.shutterfly.com/osi.jsp?i=EeIOWjli1ZtX4A">Shutterfly Pics</a></li></ul>
<center><img src="http://www.marineturbine.com/bike_images/bike_yellow.gif"></center><p>Engine:
Rolls Royce Allison
250 gas turbine
Power
320 HP @52,000 rpm
(286 HP @ rear wheel)
Output RPM:
6,000 rpm
Torque:
425 ft/lbs @ 2,000 rpm
Compressor Speed:
54,000 rpm
Fuel:
diesel, kerosene
Lubrication:
dry-sump/3.5 quarts turbine oil
Transmission:
2 speed automatic or manual
Rear Mirrors:
rear mounted camera with LCD color
display plus rear view mirrors
Options:
single or double seat, custom colors
Frame:
aluminum alloy
Rake:
27 degrees
Weight:
500 lbs
Seat Height:
31.5 in
Wheel Base:
68 in
Wheels:
17" carbon fiber, Dymag
Tires - Front:
120 60ZR17, Pirelli
- Rear:
200 50ZR17, Pirelli
Front Forks:
55 mm inverted
Shocks:
mono-shock adjustable
oleopneumatic, Ohlins
Brakes:
3x320 mm floating system- 4 piston
calipers, Brembo
Fuel Capacity:
8.5 gallons (34 liters)
Radar Detector:
forward and rear-looking radar
with laser scrambler, K40<ul><li><a href="http://www.marineturbine.com">Marine Turbine Website</a></li></ul>
Rolls Royce Allison
250 gas turbine
Power
320 HP @52,000 rpm
Output RPM:
6,000 rpm
Torque:
Compressor Speed:
54,000 rpm
Fuel:
diesel, kerosene
Lubrication:
Transmission:
Rear Mirrors:
Options:
Frame:
aluminum alloy
Rake:
27 degrees
Weight:
500 lbs
Seat Height:
31.5 in
Wheel Base:
68 in
Wheels:
Tires - Front:
120 60ZR17, Pirelli
- Rear:
200 50ZR17, Pirelli
Front Forks:
55 mm inverted
Shocks:
Brakes:
calipers, Brembo
Fuel Capacity:
Radar Detector:
Kgnast-Nemo4.2
10
08-01-2003 05:30 PM
Kgnast-Nemo4.2
07-31-2003 09:40 AM
