some spark plug info and questions
I have done a search and really didn't get an answer in searching of " difference of copper core vs v- electrode vs platinum in performance /plug life" ...so your input would be helpful.....
The following is all NGK & o.e. numbers & heat range......
Copper core BKR6ES base cost=b
V-electrode power BKR6E base cost=b
G-power platinum BKR6EGP Base cost=b x 2
Iridium BKR6EIX base cost=b x 4
O.E.platinum/iridium PFR6Q base cost=B x 6
the O.E. part evidently is licencesd to NGK thus the big price. Not being familiar with the 1.8 motor in particular I would like input. In general I have found that platinum tip gives far more life /performability (whatever that means) in most (but not all) motors but I have no learning curve with the 1.8L. What say the experts ?
and if you have any kind of tune going, i would really stay away....
PFR6Q is stock....you can run Denso Iridium IK20's or IK22's if you are running more mods and higher boost..
I run the Denso's and find they need to be regapped every 10k or so to eliminate unnecessary wear on the coilpacks. Figure the life expectancy to be around 20-25k on the Denso's as well...
TT and is pretty sensitive to electrical...so, i would go with proven solutions and not the gimmicky stuff IMO
thanks the input TT...
""""so, i would go with proven solutions and not the gimmicky stuff IMO"""""
Thats why I want to stay with NGK. No mods, none planned...I'm kinda leaning towards the platinum or irridium plugs. 25 K is three years driving...so milage isnt much of a factor. and I understand the gap issues etc in newer posts.
In my experience, they last much longer than others (they go 40K+ for me, IK20's went about 20K, I tried some BKR6-somethings, less than that).<ul><li><a href="http://dieselgalaxy.com/product.php?productid=88573">$21/set, cheap.</a></li></ul>
with the exception of an occasional intersection....;-P
j/k
Actually, like i said "generally" which does not mean "all"...Some have had success....i have just seen a lot of the cheaper/copper plugs cause problems over the years, and less so with a stock solution....just my opinion...
j/k
