sourcing out 14mm x 1.5 extended tuner lugs for axis wheels...?
I read some posts regarding axis wheels and people needing at least a 1.5" thread length to fit a 13mm FK aluminum spacer. What I didn't find was where the source was to find these mysterious longer tuner bolts. Unfortunately, a thin walled 17mm socket will not fit into the axis bolt openings. Any help would be greatly appreciated in sourcing these out.
thanks
charlie
thanks
charlie
They don't sell direct. They put me in touch with one of their distributors in order to place the order. Their number is 800-222-4292.
<center><img src="http://i186.photobucket.com/albums/x289/actorlany/ball___tuner_seat_lug_bolts.jpg"></center><p>Where exactly did you get them and do you recall if there was a manufaturer like (gorilla)? where they the spline drive with the long thin round key?
or was it something more like this?
They have worked very well for me. I believe that I was also referred to eHubCap.com. When I get home this evening, I can verify the exact product number I ordered.
I'm running a staggered setup. 9.5" in the rear and 8.5" in the front, with different offsets. By using 10mm spacers all the way around, the wheels ended up coming very close to flush; just a bit inside.
808Guy
08-09-2006 04:40 PM
BlueChip
16
03-31-2006 02:59 AM
MVSantorinS4
02-27-2003 09:08 AM
channelv
11-07-2002 11:23 AM
