Spacer help...(3rd try, it's not posting for me!)
Hey,
I just got 18x8.5 BBS CH's with 235/40 Potenza S0-3's, and Bilstein PSS-9 coilovers. I want to lower the car to set the wheel well right on the rim, but I also wanted to fill the wells. What size spacers do you guys (and girls) recommend for me to get in order to do this?
Thanks a lot
Nate
Thanks a lot
Nate
the rear spacers will usually be larger than the rears. With 8.5" rims, you'll want the fronts to have an offset of about 20mm = (wheel offset + spacer), and the rears to be about 10 - 15 mm. If the BBS offset are around 35mm, you'll want 15mm f and 20 or 25 mm r spacers to get down to the numbers I indicated.
DirtMonkey_NWB6S4
09-08-2001 10:56 AM
