Spec 2+ clutch and Aluminum Flywheel Impressions>>>
#21
just remember it is really not the clutch that is the issue...it is the quirkiness of these cars....
Some tuners blame some of the cheap parts...others blame other things....
seems to me there is something a miss with the execution if your setup is still wonky...
Did he ever check the cables to the tranny? My got re-adjusted/tightened and that helped quite a bit...it is basically back to normal now
#24
Spec should really explain specifically that your car is going to sound like a model T with that flywheel. Some cars run fine with this set-up.....the TT needs that extra rotating mass to work properly, Period!
#28
Yes, I am having problems up-shifting, more so than down shifting. I did some research and I found out that it has a lot to do with the lack of inertia force from the lighted flywheel. I tried a 3500 RPM launch and the car bogged and fell on its face. I guess that 4cyl just needs the extra weigh of the steel to give it that force and momentum to aid it in shifting and launching.
#30
I personally have not used lemmiwinks before so proceed with caution or ask a bunch of questions/do research.
<a href="http://forums.fourtitude.com/zerothread?id=1618056">Fortitude - Lemmiwinks the Guide</a>
<a href="http://www.vwfixx.com/forums/index.php?showtopic=15329">VW Fixx - Lemmiwinks download and guide</a>
Also, just doing a Google search nets <a href="http://www.google.com/search?q=lemmiwinks+software"> this.</a>
