Spoke with 42DD- a 180Q DP is available (street version w/hi-flow cat is $575+$25 s/h).
#11
just re-register in TX.
There isn't a need to have it inspected in CA.
Or, am I missing something?
#12
Counties with poorer air quality require biennial smog inspections. And it's not just the urban counties like LA, San Diego, San Francisco-- even rural counties can have air quality that is poor enough to require smog inspections.
And it's not always county-wide, some counties require smog checks based on zip codes within the counties<ul><li><a href="http://www.dmv.ca.gov/vr/smogfaq.htm">Cal DMV Smog FAQ</a></li></ul>
#14
pass, but it would not be legal. It should fail for no certification, and it should fail for visual inspection. That said, mine passed with a Greddy DV, full SFS hoses, Borla exhaust. I did swap the OEM air cleaner in for the TTDA for the day.
#15
as long as you do not sell the car or do anything that would require CA registration<ul><li><a href="http://www.dmv.ca.gov/pubs/brochures/fast_facts/militaryvr.htm">Check here</a></li></ul>
#16
were lower than when I bought the car new and it was fully stock.
Test shop made no effort whatsoever to look for CARB cert anywhere on the car, or even look under the car. As a quattro, it is not even tested under load on the rollers (as is required now), just tested at idle and higher RPM.
#19
in a "clean air" county and they'll move asap I'm sure!
(We have far too many "hippies" in So. Co.)
My town is one of the very few that is exempt. It's nice to not have to go through the hassle.
