Step-by-step fuel pump replacement
#24
The one where the trunk release handle is.
I imagine the lack of working space (and light) makes it a good bit more difficult, though.
Very glad that it worked out!!
#25
hey everyone, ive got a 2002 convertible TT 2 seater quattro, cant seem to find the location of the fuel pump since i dont have back seats, any help would be so greatly appreciated thanks
#26
The primary fuel pump is located on the passenger behind the seat and behind the plastic covering that cover the speakers. You first have to remove the center speaker cover (be careful as it can break) then you will see 4 screws to remove the center plastic cover. Once that is off (there are a few clips holding it in place. Then you can remove the plastic cover that will expose your passenger side speaker and seat belt housing. there will still be a storage box in the way where the inside trunk release is. You need to remove the two screws holding that and then two plastic retainers. Pull this to the side and underneath there you will see a metal cover with 3 screws. Remove them and you will see the primary fuel pump.
#27
thank you for the reply, i will keep this thread once my fulepump goes bad, but in the mean time i had the car checked and it ended up being the Crankshaft Engine Speed Sensor
so for anyone that has the same issue as me, check your crank shaft sensor, its an easy fix, and you can find one for under $50
#28
Anyone know if there a version of this walkthrough that still has the photos attached? I need to do this job on my 2002 TT Quattro. There are lots of DIYs on the web, but none that I've found that show the hose fittings for the dual pumps/floats the Quattro has.
#30
I have found this link which has just a few of the photos, though still missing most of them. HTH. I too would like to see all the photos before jumping in to the project.
How To: Audi S3 Fuel Pump Replacement (The cheaper way...) | Audi-Sport.net
