stereo help!!!!!
Does anyone have any suggestions on what new stereo I should put in my new '01 TT Quattro Roadster (black/black/black)? I would like to have am-fm-cd it came with the am-fm-cassette. Pictures are also welcome.
Thanks!!
Thanks!!
If you wanted to keep the system somewhat OEM, a 'Concert II' H/U, with the built-in sinlge CD, upgraded amps and speakers would be a good combo.
If you are enamored by those Asian-colored, dancing H/U displays, and all the push-buttons, any decent one of those, again, with a built-in CD would work also.
Find one that has a, aux. in port, and that plays MP3 CD's, etc.
For more OEM style, some Blaupunts are nice.
be aware that any/most aftermarket H/U's will require that you use some sort of spacer.
The Audi H/U opening is wider in the display area than other standard H/U's
The actual recessed opening is the same width as std. H/U's
Where are you in MN?
Stop by and I will show you my install, and give you some pointers on removing the rear plastic panles behind the seats to get at the components.
MBQuarts in the rears.
<img src="http://home.attbi.com/~woodyb/images/leftrear2.jpg">
Fosgate *' sub
<img src="http://home.attbi.com/~woodyb/images/subwoof.jpg">
Alpine 5-can. amp in the trunk, on a pull-out tray, with cooling fans.
<img src="http://home.attbi.com/~uhclem/images/amp4.jpg">
Fosgate *' sub
gluinenburg@wsgr.com
06-13-2002 10:46 AM
JustJeff
01-08-2002 04:59 PM
JustJeff
27
12-29-2001 04:57 PM
big tea
Audi A3 / S3 / RS 3
08-10-2000 07:48 AM
