Stupid questions..Conical lug bolts or ball-type lug bolts??
I have aftermarket wheels and it seems like these are OEM "ball" type bolts. However, don't most aftermarket wheels need the conical bolts? How can I tell for sure which bolts I need? The pic I took does not really help me.
<img src="http://www.clearpaintguard.com/audi/bolt2.JPG">
<img src="http://www.clearpaintguard.com/audi/bolt1.JPG">
Probably conical...>>
But it's hard to tell from that pic. If the seat areas are straight then they take the conicals shown on the left..
<img src="http://pictureposter.audiworld.com/13940/dscf0099.jpg">
ECS has both.
<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&engine=225HP&mo del=TT&submodel=Quattro&category=Suspensio n">ECS</a></li></ul>
Former Vendor
hard to tell, but..
You can see in your lug bolt hole how the top portion of the hole is more worn than the bottom. That's a sign that you most certainly have the wrong bolt seat. It could be a small diameter ball seat that you need, or you need a conical bolt.
You should check with the wheel manufacturer.
CTA4AVANT
05-08-2004 09:21 AM
