Sway Bars...which one is more necessary to upgrade?
AudiWorld Awesome User
By design, you understeer a bit, so you need more roll-stiffness aft.....
A better rear anti-roll bar will give sharper turnin. But if too large can either cause wheel lift and/or oversteer.
Balance, in all things.
Re: By design, you understeer a bit, so you need more roll-stiffness aft.....
so how's neuspeeds 28mm?
and when i eventually do the front...neuspeed or eibach?
The Neuspeed 19mm has gotten
favorable reviews from juliem IIRC at West Coast TT. 28mm is a honker for understeer correction, and you may find yourself a bit dicey unless you go to a performance driving course.
But that's just MHO.
Why do you want to do the front?
thicker sway bars make the suspension less independent. Yes you can dial out understeer by going with a larger rear bar but with that comes some other issues.
Would these setups be ok?...............
Can anyone pls. comment on which is an ideal setup for a TT180 Frontrak.
a) stock front bar / 25mm rear
b) 22mm front / 25mm rear
c) 25mm front / 28mm rear
Thanks.
Thanks.
Jersey John
04-02-2010 12:37 AM
FCastigl
A4 (B7 Platform) Discussion
10-24-2005 07:23 PM
momotoTTe
03-20-2004 09:41 AM
White Coupe
03-27-2002 10:13 PM
