Tech assistance ?....LarryTT or Mance or Denny...
<center><img src="http://pictureposter.audiworld.com/4128/caliper_retainer_bolts.t.jpg"></center><p>as you can see in the pic the bolts hilited, I need the torque setting for the brake caliper retainer bolts and should I use 'lock tite' when reinstalling bolts. Appreciate help....
I have included 2 pictures to make sure I am seeing the correct bolt. The answer is 25 Nm for Bolt #7. Is that the one?
<img src="http://larrytt.dnsalias.org/images/misc/frontbrakes.gif">
<img src="http://larrytt.dnsalias.org/images/misc/frontbrakes2.gif">
looking at pic and you see bolt 10 but has a corresponding bolt directly below (look at where dashed line goes from bolt 10 makes 90 deg turn down and go about an inch and there is another opening just behind dash line for the other bolt. Anyway...same size and same purpose so if you have torque spec for 10 then the other is the same.
Thanks
Thanks
7 - Guide pins, 25 Nm
Removing and installing Page 46-5
8 - Protective cap
Take off
9 - Brake hose with banjo union and banjo bolt, 35 Nm
10 - Ribbed combi - bolt, 125 Nm
Clean ribs
11 - Wheel bearing housing
12 - Hexagon socket head bolt, 8 Nm
13 - ABS speed sensor
Before inserting sensor, clean fitting hole inner surface and coat with lubricating paste G 000 650
14 - Splash plate
15 - Hexagon bolt, 10 Nm
8 - Protective cap
Take off
Clean ribs
14 - Splash plate
pearlwhitesix
12
03-29-2012 09:31 PM
snarlofdisgust
05-07-2010 09:01 PM
evils4
09-19-2004 07:36 PM
LJ.925
03-06-2004 10:00 PM
