Tech Question: Does a blown DV valve always show up on a VAG diagnostic??
Hey Larry how do I get the shovelheads at AUDI to replace DV valve if its not showing up
on VAG diagnostic?? Im getting the Forge but meanwhile I want the convience of having audi install the hose clamps so I can swap it in and out... any comments on this would be great
Just bitch and moan . . .
explain to the dealer that the car is way don on power. You talked to your "friend" that has the SAME model as you and his has much less turbo lag. Tell them that your friend had his dealer replace HIS DV ad it made ALL of the difference in the world!
Explain to the dealer that VW and Audi have admitted tha the DV is defective. Tell them that is why Audi & VW are up to the letter N in version releases! Once they realize you do know something they should give in! Tell them that your car either has a G or an H valve adn those are BOTh known to be defective. Tell them that the N is supposed to be the fix, even though between you and me . . . IT'S NOT! lol
Explain to them that you don't want a piece of the diaphram tearing off and blowing your turbo!
All of the above should scare them enough into relacing it. If that does not do it, then call AoA and make a HUGE stink!
ThirdEye
09-27-2002 09:06 PM
ErikNYC
Performance and Tuning
03-27-2002 01:40 PM
Rob S in PA
11-22-2001 09:20 PM
Jon G
10-07-2001 12:16 PM
