Is there a better than OEM shock/spring setup that...
does not change the ride height at all - I want to upgrade my handling, but do not want any changes that alter the suspension geometry and require spacers and all that nonsense...
The springs are actually pretty good...>
Throw a set of Bilstein HD's on there and you'll have a new car. I ran mine this way for quite some time, and it is an excellent combo...Better with the Neuspeed rear 19mm bar...
Yup- Amazingly enough (Ha!:>), I totally agree with Schwing:
I ran stock springs and Bilstein HDs for a few
years and they're a great combination. Added the
rear sway bar this year and it's even better. I
think I'm actually done suspension wise, although
there have been people trying to convince me that
H&R coilovers are the bees knees. Could be, but this
is a cheap, easy, and quite capable way to go.
Highly recommended.
scot
Highly recommended.
scot
Stiffening the rear...>
Will dial out a bunch of understeer and make the car a more pleasurable overall driver..
If you wanna get serious, bump the front up to the 22 (from 20) and the car gets real aggressive......(I've got a whole lot of other things going on, so your mileage may vary...)
Good combo. Will handle much better.
Especially if your shocks are older than 10k. I eventually decided that it was too soft and upgraded the springs later. Wanted Eibachs, but had to settle for H&R's, as there was some sort of national backorder. The rear sway bar should be a no brainer.
The car is nice and tight now, but a little *oof* stiff when you *oof* hit the bumps. At least now I can swerve to avoid them with confidence!
