Is there a way to log N249 duty cycle?
Still getting some hesitation as boost builds. On gas pretty hard, not WOT, and at about 10psi it cuts out and stutters a bit and I can hear what sounds like the DV cycling. I already replaced the N75 and that seemed to fix things a bit (no longer surging to 30psi). I'm wondering if the N249 is on its way out or perhaps some other sensor is and the ECU gets confused and tries to dump boost. Also, this seems to be heat related. It's much worse on a hot day so I'm thinking a sensor or something electrical and not a leak somewhere. Thanks!
When I had problems with my new turbo setup, we looked closely at the wastegate duty cycle, which of course is determined by the N75. Unfortunately, I don't recall which blocks you need to look at.
002, 118, 204
2K then WOT to redline in 3rd gear
Email me the file!
(N75 is in the 118 block. No Log for N249 that I know of...It takes its commands to dump boost from the ECU which is a slave to the sensors......all of them)
<img src="http://images19.fotki.com/v22/photos/7/7305/776256/Sensordiagram-vi.jpg">
Email me the file!
for some other (good) reason. Didn't want to possibly put a hole in the block by disabling a failsafe mechanism. I think before I pull it completely I'll swap with the spare sitting in the blue car
jwolf::ASP S3
05-19-2006 10:58 AM
Agent Orange
12
08-11-2003 01:38 PM
KgS4
26
12-19-2002 05:59 PM
