Is there a way to reset the Power Windows?
My drivers side window's one-touch function has not worked since the battery was replaced. It also takes three tries put put the window up from the completely open position (about a third of the way each time).
Any thoughts?
Any thoughts?
Yes..I think you need to open the window and hold the switch down for a few seconds longer
Should return to one touch open and close....others will quickly correct me if my memory is failing me ;-)
Marcus
Marcus
Re: Is there a way to reset the Power Windows?
1. Close window.
2. Push and hold button to completely lower window.
3. Pull and hold button to completely raise window.
4. Pull button twice.
5. Window fixed.
5. Window fixed.
98Quattro
07-05-2011 09:57 AM
