Those with Palm based VAG. Impressions? Likey...>>
I like it for the convenience, but it is not as fully featured as VAG-COM.<ul><li><a href="http://www.arlab.it/home.html">VAG-Check</a></li></ul>
Which PPC are you using?
Where did you get the interface cable?
Did you get the full featured version?
What rate does it sample data?
I have an iPAQ 5450 and would like to use it with this. I also have VAG-COM
I have an iPaq 3650. It works with any VAG-COM compatible cable, I'm using the one from www.obdtool.com. I used to use it with a serial sync cable with a DB9M-DB9M null-modem cable. I now use a cable I wired up using the iPaq cable from www.gomadic.com and a DB9M connector and housing from Radio Shack.
The main feature it is missing right now is the ability to log. You can monitor the measuring blocks, but logging would be much more useful. I have no idea what the sample rate is.
Cheers,
Rob
Cheers,
Rob
DM-S4
VAG-COM Discussion
05-09-2006 01:28 PM
leeep
05-02-2003 12:32 PM
