Those who has modded their 225s, what is the "correct" MAF/ MAF housing to get?
thinking of replacing the MAF as i fear it might be limiting the power to the car. Do I change the housing or just the MAF or both? Please provide the Part number too thanks. Will I need to modify anything for it to fit?? thanks all
and the car will probably run in closed loop...The MAF isnt a restriction unless you are looking for 350+ hp...and even then you should be more concerened about your intake hoses possibly colllapsing instead...
If you insist on messing with the MAF...do a search with the words Schwing+MAF in the target bar...that should point you in the direction of screen removal and its benefits...
BTW what mods do you have that make you think the MAF is a restriction anyway???
M,
M,
galvatron
09-11-2002 09:40 AM
