Thoughts on how to reduce/eliminate detonation without getting extreme (ie water injection)?
#11
key to the Denso's is inspect the gaps around 8k-10k....their life expectancy is about 20-25k for the plugs...they seem to like to widen their gaps....
Doing mine before TTE....I was also thinking of doing the injectors....one thing i have never done...
#16
I'm betting the timing is really aggressive on the REVO though. It's set to 3 now... I'll probably try setting it to 2 and trying one range colder plugs.
#19
You can also log timing pull with a VAGCOM. Lower the timing until you don't get any timing pull. Once there you should be set.
Is it possible you are both tanking up at the same station that has some "questionable" fuel supply?
